Front sway bar
desertdragon
Car: 2008 Altima coupe 3.5 SE with CVT Winter Frost
Does anyone know if any company is making the Front Sway bar for our coupe?
I have the Stillen Rear sway bar and Racingline STB currently in my car, but would like to add the front sway bar.
Any information would be appreciated.
mcheddadi
Car: R8
Here's OUR FSB. it's the black bar bolted on top of the front subframe. To reach and unbolt it you have to lift the car and unscrew the 4 bolts (2 each side) that hold it down. and then you need to unscrew the endlink bolts (1 at each end of the bar)
there isn't any bar available but if there is demand for it, it will happen, I'm sure racingline or stillen would release one
P.S.: on that pic the front subframe is removed but no need to remove it to get the bar out. pretty straight forward.
desertdragon
MC, thank you for the reply, I do know what does our FSB look like, I also know that it is a pain in the rear end to replace it. I had the Nismo FSB and RSB on my 05 3.5 Altima.
Just woundering who will make one for our car.
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
I thought it would be harder to access than that... hmm... Im sure someone will cook something up!
ItsEcko06
mcheddadi wrote:dadi/HLSD/HLSD102Large.jpg[/img]
looks pretty sturdy to me! then again thats for 3.5, the 2.5 is probably a bit wimpier. i guess if theres not one the 2.5ers could get the beefy 3.5 bar
