Front sway bar rubbing front tension rod?
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
Hey guy's just wondering if anyone has had a problem with the front sway bar rubbing the front tension rods?
i have a spacer on the sway bar so the oil pan on my 2JZGTE clears, but now the sway bar's (which are larger then stock hit my aftermarket tension rods) i was trying to think of a way to make a spacer or something for them but i'm out of idea's, and i don't think i will be able to make them clear unless i go back to stock sway bars....which i'm not sure i want to.
ideas?thoughts?
