Front suspension rebuild
oceanpro
Car: 1994 Nissan 4x4 Hard Body SE V6 Ex.cab Pickup Owned since new
My 1994 SE V6 4x4 is in need of a front end rebuild It has 160,000 mi. and runs great Anytime I drive around/over 55mph there is excessive shimmy and vibrations coming from the front suspension. I had the tires rotated and balanced and it made no difference. I figure the truck is good for another 100,000 so I would like to make it drive and ride like new. other than replacing the shocks and struts, what else would need to be replaced? Thanks to those that replied to my oil problem. I switched back to castor oil 5w30 and problem solved.
RT22
Car: 1991 nissan hardbody
Bushings they have to be crap by now. i am about to do mine on 91 2wd. Energy suspension makes great urethane bushings that tighten up better then rubber stock crap. Not to expensive just install and alignment will get pricey. I already did leaf springs with ES Urethane and loved it. those were 45 bucks and 150 to install.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
There are no struts in your front end.
Start with some good quality shocks. Rancho RS5188s work well, as to the KYB Gas A Justs.
Tension rod bushings would be next. That's the rear most suspension mount off the lower control arm.
Tierod ends and a new Centerlink probably wouldn't hurt either after that many miles.
All this is DIY worthy, though you will wnat to visit an alignment shop when you're done swapping out steering pieces.
kibatheloanwolf
Car: 1987 D21 2.4L with a 5 speed manual trans
2010 Camry 2.5L with a 6 speed maunal trans
Here is a rare thing guys *note this cant be good* I found out I'm still running my factory shocks x.x
seang
Car: Ford Fiesta ST
kibatheloanwolf wrote:Here is a rare thing guys *note this cant be good* I found out I'm still running my factory shocks x.x
Then you can look like Uncle Buck.
seang
Car: Ford Fiesta ST
Oceanpro, you should also make sure the front brake rotors aren't all warped, and if they are, you may be able to get them resurfaced if they're in spec, otherwise new ones. I think this should be high on the list.
oceanpro
I think that I will start with shocks and some poly bushings and maybe balljoints. I am budgeting $1,000.00 for parts and labor. I am hopeing to make it like new or better and still stay in budget. I could even do the simple things like installing shocks myself, but I will most likely pay a pro to do the rest as long as I can stay in budget.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I rebuilt my front end for around $700. I did all the labor myself using Moog and OEM parts. The only thing I was unable to do was align it, had to have my old employer do that.
oceanpro
It looks like the parts will cost about $640.00 plus $200.00 for shocks, and $150.00 for towing and alignment.the Labor quotes were $800 To 1.000. So it looks like I will be doing it myself. A friend of mine has rebuilt quite a few frontends and has offered to help me for a couple of halibut fishing trips. I think thats the best way to go. I am not sure why it would cost 800 to 1,000 for labor. How many hours did you have in the front end rebuild?
