bullittandy wrote:Almost certainly the tension rod which connects the control arm to the frame. However, at 157K you might do well to replace everything if you've got the dough, struts, mounts, tension rods and sway bar links.good luck!
JRJ- We're all in awe that you could go 157k miles without any work to the suspension. In the end everything Andy mentioned above will need replacing and it's not going to be cheap. You're going to enjoy the new ride once it's all complete.
I'm thinking the bump, bump you're feeling is from worn out shocks and you're riding mostly on springs. There's a rubber "bump stop" bushing on the strut shaft and a rubber spring pad on top that could both be worn out. See page FA-15 in your FSM.
For the most part suspension work is righty-tighty, lefty-loosey but you may need an alignment when you're done. Every instruction and part you will need can be easily found by searching and reading. Print up the best threads and take them with you when you decide to wrench on your Q. Also, take a look at the numbers from the last alignment. If any are on the edge of the acceptable range it will help tell which component is wearing out. Good luck.
