elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Dec 06, 2005 5:38 am
Alright... You just refuse to let this go!!!!!!!!
First off, feel free to call me at 765-621-8336..... Ill talk to you, because when I get started on posts like this i tend to ramble aimlessly.
I disagree on the LCA needing to be serviced. The bushing seems to be solid like, when I took it off and pushed on it, it didnt seem to be like the other bushings, more like a solid rubber.....
Id leave that alone... I chose not to upgrade the LCA for the follow reasons: It hardly goes bad, it doesnt need to be stronger because the stock sway bar will never come close to breaking it, the bushing ive never seen go bad, ive been under enough high mileage Q to see if they show signs of going bad. It wasnt because I couldnt afford it. I didnt think it was necessary. If the ball joint is bad (I doubt it will be) you can get a 300ZX one and press it in.
You should be able to replace the steering rack bushings with poly ones for a 300ZX. The Z uses pretty much the same rack except its shorter... I replaced Jesda's steering rack bushings, and its not simple or fun to replace.....
Sway bar bushings- Honestly, id get the OEM bushings for the frame bushings, they do wear out but are cheap and wont squeak..... In the spring, im going with poly all around on new end links. There are 2 frame bushings per front bar, and 4 end link bushings. Theres really not much performance benefit by using poly in the middle since theyre only there to hold the sway bar in its proper place.....
Just remember if you get the midori upper links, you MUST get the solid type tension rods, you should know that already....
If you want to run the cali customs you really should use a stiffer shock... when it comes time to replace mine (Spring 07), im going to look into geting some KYBs from a skyline, i think theyll go right in but we'll find out... I think coilovers are pointless, but thats just me... The cali customs give me the ride height I want, i have no reason to set it lower.. Plus, with coilovers you cannot replace the shock in most cases... you have to replace htem, and that gets very expensive... Most people I talk to have bad luck with coilovers, and the skyline people Ive talked to dont really like them.
You wont be able to make end links for the front sway bar as they have a ball joint that connects to the sway bar, but you could do it for the rear... I say, why bother?
