philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.html
Sat Sep 11, 2010 2:28 pm
I've noticed a metallic knocking noise the past few weeks. It happens every time I hit a bump on one side only. So today I jacked up the Rogue, and pulled the drivers side front tire. It suspected an issue with the sway bar end links and that's exactly what I found. They have worn out and there is some play in them. Every time one front tire hit a bump, the sway bar twists and the ball joints in the links 'knock'. If I hit a bump with both tires, the sway bar moves in unison and there is no load put on the end links and no knocking noise.
This is not surprising really. The roads where I live are not in the best of shape. The constant banging from potholes and frost heaved pavement have taken their toll. I have 65,000mi (109,000km) on the clock.
The repair is simple, remove the 4 nuts, remove and replace. It shouldn't take more than an hour. I don't know the parts cost here in Canada. But in the US, the links are $27 ea.
I'll post a few photos when I perform the repair.
