...really? Is that because it only uses two bolts/tower?alphapig wrote:Not sure, seems like all 3 bolts may be slightly stiffer though? It is nearly the same contact area, however.
I definitely recommend the strut tower brace though, surprisingly noticeable improvement in handling.
Remember that the Racingline brace doesn't immediately work with BC coils. Stillen fits fine though.
gameguru1360 wrote:I'm using factory shock coils. So the stiffness isn't that much of a difference with the Stillen only using 2 bolts??
which finish did you go with?? the black or the polished??rcboy514 wrote:
it won't make a noticeable difference, I mean you could argue that 3 bolts is stiffer and stronger under load, but for our application the difference is negligible. Go with the one that you like the best, I went with the racingline's because I wanted a more subtle look.
Confirmed!prlwhitecoupe wrote: Is this confirmed??? I just picked up the BC Coil overs and I already have the Stillen FSB....I won't need to make any modifications? Cause thats awesome....
