Razi wrote:Energy Suspension is a popular choice for a lot of people.
If you're thinking about redoing all the bushings in the rear with polyurethane, I wouldn't recommend it. Just doing the tension rods shouldn't be too bad though.
The bushings are supposed to twist as the suspension moves, but a hard bushing will resist that and bind, and your suspension won't move as smoothly as it should.
Wow, thanks, Razi! I intended to buy the kit days ago, but hadn't gotten around to it. You saved me a big mistake!
So this twisting is probably related to the way the rear suspension toes-in the wheels for stability under trailing throttle?
So should I buy polyurethane for the front end suspension or will I then have mismatched handling front and rear (oversteer I would assume?)?
In my gut I "know" that it is probably my strut bearings that are the problem, but I was hoping that replacing the cracked rubber bushing on the tension rods might be the cause of my clunk since it occurs under braking and under acceleration.
I have an additional clunk from the rear end when I reverse out of a parking spot with the front wheels turned to full lock. My parkign brake was boken for 4 years (!) and I was parking the car in reverse... so I'm thinking that doing that on inclined surfaces repeatedly may have killed the rear diff bushing...
Now that I have started paying more attention I realize that the steering is not quite as quick as it was (possibly the bushings attaching the steering rack?).
As of today and yesterday, I notice when I accelerate hard while turning right onto a freeway on-ramp it feels like the car is "losing its line" very slightly, feeling like it is drifting a little wide and there is a numb feeling in the steering- like there is slop. From the rear end.
All of these handling issues are new (or I didn't notice due to the gradual nuature). The car is a '93 non-SE non-HICAS hatch with only 140,000 miles. I've never had to do anything to this car except a clutch pressure plate (did clutch too of course) at 137,000 and a thermostat 4 years ago. I love these cars!
What kit do you recommend?
I'm on a serious budget and under-employed so maybe I'll just start with the tension rod bushings and see if it improves. Do you recommend rubber ones from the dealer?
In the event that I have to do the strut bearings (bushings?) do you recommend dealer or is KYB or some shock company good enough quality?
Thanks for your help!!!
I'm also going to post a thread "Where do you buy LSDs? Canada?" (I'm in Seattle)
