good responces
From what i've gathered over the last year or so reading about suspension, is that there are a couple of conflicting issues with spring stiffness/oversteer/understeer.
Should you increase stiffness at the rear of the car, this will increase the oversteer characteristic. BUT.....should the roll stiffness be increased, reducing body roll, the camber of the tires will be more optimum for grip, and actually reduce oversteer. Generally speaking. (ie: camber curve aside)
I could then (with hesitation
) say that the modest camber curve of our front mcpherson struts as compared to the multilink rear, would gain grip moreso from a reduction in bodyroll. So, perhaps at the coilover 9/7 level, the higher stiffness at the front may actually improve front-end grip?
It seems that there is much interplay of these issues with springs/swaybars.
