moose_grunt »
https://forums.nicoclub.com/moose-grunt-u266704.html
Sun Jul 31, 2016 3:12 am
Hi all. I've been a stalker here for the past few months after I bought a 2001 Pathfinder. I've finally been emboldened enough to tackle replacing the worthless front strut. It went about as expected-took me the entire weekend, made even longer because I only have the one car. Had to put everything together to run to the hardware store a couple of times to buy sockets I didn't have...
I replaced:
Passenger's side strut (Sensen)
Knuckle bolts and nuts (OEM)
Top mount (including bearing and mount nuts) (Duralast)
I finally got the job done, but now get a clunk when making a hard turn slowly. Watching the spring, it moves smoothly, catches, then jerks. I've got the bottom pigtail aligned correctly, and the notch on the top plate matches the notch on the bottom. I used a Duralast mounting kit, so put in a new top mount, bearing, and nuts.
I'm thinking that I over- or under-tightened the nut on the top of the strut, as both the strut and nut turn a little when I turn the wheel. I assume that's not supposed to happen (doesn't on the other side of the car). Any ideas? I'll probably tear everything apart and put it back together again next weekend to see if that hleps, but any other suggestions would be great.
Thanks!
Jim
