whathappenedtoleeds »
https://forums.nicoclub.com/whathappenedtoleeds-u288784.html
Tue Mar 26, 2019 7:59 am
I've searched this forum a lot about issues and questions I've had about my QX4 and I have found a lot of good information. I was having issues with my front speakers popping in and out/on and off. What would happen is the front speakers would pop on and off when the car was first started and then after a few minutes the left speaker would stay on, but the right wouldn't come on at all. It originally started when the music would be above a certain volume, or was bass heavy.
I saw on here that the issue might be with the head unit. I bought an aftermarket head unit. I installed it yesterday and the issue was still happening. I messed with the fuses to see if that was an issue, but that didn't seem to do anything. Then I decided to take the door panels off to check the speakers. As far as I could tell everything looked good. I then decided to see what would happen if I unplugged the right speaker. When I did that the left speaker immediately started working. I then took the speaker amplifier from the left speaker and hooked it up to the right speaker, and vice versa. Doing that the same popping happened but the right ended up working, and the left didn't. So, I figured out that it seems to be the amplifier for the right speaker that is bad. I have unplugged the right speaker for now, and ordered an amplifier (Bose amp 5300 front 077) on ebay that I guess is from a salvage QX4. Today though, if I turned the radio to a certain volume the left speaker started popping on and off a bit. I'm wondering if anyone knows what might be going on with the speaker amplifiers and why this is happening. Also, is there a fix other than replacing the speaker amplifier or the speakers themselves?
