Front Speakers for S14
Post all your Nissan electronics, car audio and stereo questions here!
kidzero81
Car: '95 S14
What do you guys recommend? I have tweeters in my A-pillars. My front speakers blew, so I'm wondering was is a good pair to get, I'm on a budget, so if you guys could help out, that'd be great. ^_^
Rex
Car: None
Well, I think there's a few questions
- Do you have the factory amplified speakers?- (If so) Do you plan on adding an amp for the new speakers?- Do you have any woodworking skills?- Factory HU?
Okay, I'll just say check your local Best Buy/Circuit City/etc and look for "open box" 4x6 speakers (6.5's if you want/can make your own adapters). I think Pioneer has a very good entry level speaker.
I think the answers to my questions may mean you have alot of decisions to make.
AustinSilvia
Car: CARS, nissans sr20det ftw!
what exactly is your budget?
kidzero81
Car: '95 S14
I do have the factory amps. I'm still new to the whole audio stuff. I just want speakers right now that will sound good, then I'll move on to the bigger stuff at a later time. Budget would probably be around the $100-150 range I guess.
PoorManQ45
Rex: When you have seperate tweeters like in his car and 94+ Q45s, do you also have tweeters with the speakers in the doors?
Meaning, if you have tweeters in the A-pillars, do/should you also have 2- or 3-way speakers in the doors?
Or, is it better to use a crossover network and only send the mid/low frequencies to the door speakers?
Rex
Car: None
PMQ, I think it would depend on what you want to accomplish.
IMHO, I would do seperates or as close to them as possible. Meaning, I would either look for a mid driver or accept a 2-way with good low end and cross over the highs out of it.
One of the best systems I ever had consisted of 5 speakers, ranging from 10mm to 15" .
PoorManQ45
How is the 94+ Q45 system setup? Are the the high frequencies crossed over to the tweeters? or are the high frequencies played by both the indoor speakers and the tweeters?
Rex wrote:Meaning, I would either look for a mid driver or accept a 2-way with good low end and cross over the highs out of it.
Good suggestion. I would especially look for a mid driver (not 2-way) if the high frequencies were going to be sent to the tweeters only.
Rex
Car: None
PoorManQ45 wrote:How is the 94+ Q45 system setup? Are the the high frequencies crossed over to the tweeters? or are the high frequencies played by both the indoor speakers and the tweeters? ...
Not sure, as I've never pulled the the door panel, but my understanding is the in door amp sends mid to door speaker and highs to the A-pillar tweeters.
