Rucca wrote:50 is the profile, it tells you the height of the sidewall as a percentage of the width. A 50 series tire is 50% as tall as it is wide. To find your sidewall height you would multilply 195 x 0.50
So, being that you have a 195/55/16 and a 205/55/16, the 195 has a tire height of 107.25mm (195 x 0.55) and the 205 has a tire height of 112.75mm (205 x 0.55). So one side is going to be 5.5mm taller...a little less than 1/4 of an inch. If it looks like one side is just barely higher by less than a 1/4 inch, then your solution is getting a tire to match the other. If it's higher than more than that, then it might be something else.
Lopin18 wrote:Grrr i dont quite understand the wheel specs, gonna start reading, today i lowered the car more, the tyres touched the coil =\ used some spacer reduced camber and its ok i guess, gonna pair same wheels and try, cause now im hearing a cluck when a heavy fall hits the car, i think im bottoming the coils =\
If they're adjustable coilovers, then make them stiffer. But that means you'll have to increase your ride height than they are now. Either that or do some drastic weight reduction on your chassis.
