Front Right Brake w/ABS Seized and Stuck
high flya
Car: 1993 S13 240SX SE Hatchback (Project)
2002 E46 M3 Coupe (Depleting my $$$)
2015 YZF-R3
2011 BL Mazda3 GX Wagon (Beater 3)
Any advice on how to get my caliper, pads, and disc apart? They are "fused" together with rust and won't budge. Thanks in advance.
MaximA32
I'd try using some penetrating oil and some elbow grease in combonation with a decent sized screwdriver or mid sized prybar. Are the caliper bolts seized as well? If they are, try heating them up and just work them back and forth to loosen the corrosion.
high flya
2015 YZF-R3
Got the two caliper bolts off, but the pads have bonded to the disc. Will "liquid wrench" work? Where should I wedge the screwdriver/prybar?
MaximA32
I assume you're replacing the rotors as well. If so, just wedge the prybar between the pad and the disc and give her agood yank. And yes, liquid wrench will work just fine.
high flya
2015 YZF-R3
Thanks, I'll get that a try.
high flya
2015 YZF-R3
Stewed it in liquid wrench and it worked like a charm! Didn't even need to pry.
Question about the caliper: The piston popped out when I pushed the brake pedal, the rubber seal/boot on the piston seems fine, but there's rust on the hollow inside part of the piston.
Do I need to replace/rebuild, or can I hold off on it?
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
If there's just a small amount of rust, sand the surfaces and clean with brake fluid, not gasoline. Reassemble the caliper, bleed the system, then see if the caliper piston has any leaks; if not, you're home free. Make sure the slider pins are lubricated.
