front q sway bar questiions
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
i have the front sway bar that came stock on my base model Q 29mm does anyone know if the energy suspension brackets are an exact replacement for stock brackets ??
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
yeah they'll work.
jamesmost
wes check ur e-mail
elwesso
2007 BMW M Coupe
Got your email...
for those who are interested, James contacted the guy who he bought his 24mm rear bar from, said they dont have them anymore but someone else can make them (not surprising)..
Sounds like they need to sell 30 bars if they remake them?
ddrumman
Car: 08 FX35 39,000 mi, 07 G35 55,500 mi, 72 MGB
Why not use the 24mm to make a 22mm which according to Q45tech should be ideal. I seem to recall Dennis mentionig that 22 would be the one.
jamesmost
ddrumman wrote:Why not use the 24mm to make a 22mm which according to Q45tech should be ideal. I seem to recall Dennis mentionig that 22 would be the one.
i hear what u r saying, i personally liked the 24mm that was on my car, little tail happy. Interested to try the 20mm.
i will call the fabricator and find out how many they need to make for a small production run
Q45tech
The problem is one rear bar size doesn't fit all [in that some have stock springs and some have lowering springs] when stock rears are 123 and aftermarket have a rising rate beyond 200.
Same with tires some have 400 treadwear and some 160, some have 65 aspect and some have 35.
Some want the car adjusted for a single driver and some want a passenger and rear passengers and or trunk weight.
Change the weight load by 5% [~~200 pounds] [especially in the rear of CG line] and you are out of tune!
Put a combination of 200 pounds in rear seat/trunk and suddenly the Q balance is 50/50.
jamesmost
Q45tech wrote:The problem is one rear bar size doesn't fit all [in that some have stock springs and some have lowering springs] when stock rears are 123 and aftermarket have a rising rate beyond 200.
this is all great information, and i agree, but you have to take the bad w/ the good and find a balance u can live with
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
jamesmost wrote:this is all great information, and i agree, but you have to take the bad w/ the good and find a balance u can live with
Probably why he does not recommend the 24mm, but does recommend the 22mm.
Q45tech
I use a 20mm with Eibach and 400 treadwear Michelins, the 28mm front bar makes the 20mm seem like it is a 20.75mm rear bar stiffness ratio shift wise.............what would be required with a 29mm front bar.
Realistically we are getting too nit picky. No matter what size someone makes there will be a group that thinks it's wrong. Some will want hollow and some will want the less expensive solid.
elwesso
2007 BMW M Coupe
I think the 20mm provides the best overall for ride quality, handling, safety, and driveability for all seasons...
