flex128 »
https://forums.nicoclub.com/flex128-u219053.html
Thu Jun 19, 2014 10:43 pm
If you'r talking about the front drive shaft i had this same issue and you will need to replace it. The joint is tapered in so it's not an easy rebuild unless you have all the equipment to do it or can find a shop that will do it and hope that its not to badly damaged
