Front passenger side noise at speed
All things Altima Coupe.
rackem22
Car: 2008 Red CVT Coupe 2.5 premium.
When i am on the highway 120+kph (75+mph) I get a wind noise from the right passenger side by the base of the windshield. I have tried wipers on/off to see if they were causing it. I have pushed on the glove box, speaker covers and dash. Nothing.
any ideas? anyone else getting/had this?
mrodrig2
Car: 2008 Altima Coupe 2.5S CVT
I recently noticed this exact same thing. I have no clue what the source is and it drives me nuts. It's not the windows, wipers, moon roof, vents, sun visor, glove box or speaker/radio. I think my windshield wasn't sealed properly or perhaps the seal has cracked somewhere because of the transition to the cold weather. I'm going to the dealer for service anyway so I plan on mentioning it at that time. The only problem is that I experience it at 70+mph too but the speed limit is 65 so I doubt that they will be able to replicate the conditions to hear it.
rackem22
well im glad (in a bad way) thats its not just me
Please keep me posted. I too will have the 'speeding required to verify' problem.
I dont go for service for another month... i will be having them look at it too
Rmuth25
Car: 08 Altima Coupe 2.5s CVT [Premium & Tech Packages]
rackem22 wrote:well im glad (in a bad way) thats its not just me
I have the same exact thing....where do you live? Because mine only does it when its cold outside. I am assuming the seals between the dash and the windshield are not tight and some air is squeaking in making that maracas rattling noise. Last year I took it to the dealer and they did nothing about it. Said they didnt notice anything "out of the ordinary."
rackem22
Im in burlington, near toronto.. Yes its cold.. although mine has done it since i got it 2 months ago.
mrodrig2
Dealership couldn't replicate the noise at low speeds. They didn't want to bring the car onto the highway because it was beginning of rush hour. If I want to leave the car overnight or bring the car back during the day they will try to figure it out when there's less traffic. I haven't decided yet if I am willing to let them diagnose this knowing that they will take it out on the road at high speed without me there. If I can get time off of work though I'll definitely go back and see if we can pinpoint it.
dhold
Car: 2008 3.5 SE
Did anyone ever have this fixed? Mine does the same thing, only when the temp is like under 40* F. The dealer spent a day trying to analyze it last spring and ultimately they called it regular wind noise, which it is not. I only have one more winter under warranty, so if somebody found a solution, I'd love to hear it.
Thanks,Don
rackem22
THe dealer went with me and acknowledged the noise, they suspected it was the hood vibrating, there was also some plastic trim around the window seals, they tried to secure that as well. In the summer the windows are open so I can't hear it anymore.. but they didnt fix it.
QR25DE
Car: 2009 Altima Coupe 2.5L 6MT Turbo
It's the windshield cowling. It doesn't line up properly. If you take it to the dealership they can order it new under warranty. Lots of people have had this issue.
dhold
Car: 2008 3.5 SE
Do you know if it is the cowling below the windshield wipers, in the bottom corners, or the sides of the windshield? Or does the windshield need to be removed? If there's any way I can fix or replace it myself, I'd rather do that...
Thanks for the info,Don
76er
two suggestions, i get similar noises at times
1) if you open up the hood, the piece of foam/plastic right under the hood seems pretty loose. If you put pressure on it with your hand, it makes a rattling noise....never really confirmed if its the same noise
2) The back seat cup holders, that whole back inner panel is 1 big piece which rattles for sure. Maybe thats the noise.
dhold
Car: 2008 3.5 SE
It's not a rattle or anything, it sounds like an air leak. I saw a few posts describing it as radio speaker noise, but it can be heard when the radio is off. For me though, this is only an issue when it's cold, like below 35 or 40 F.
newname
Yep, it just started for me also when the cooler weather hit. I have had my 2009 coupe since June and this windshield noise on the driver's side lower corner just started a month ago. It is fine until I hit 120 KPH and then it sounds like radio static...called dealer and he says no one else had complained about it...
Modified by newname at 9:11 AM 11/18/2009
newname
Can you send a pic of where the cowling doesn't line up? Everthing looks ok on my coupe...
Truerocket11
Car: '09 Nissan 370z Premium Package
'08 Nissan Altima Coupe 2.5S
I've recently just noticed this as well...Im not sure its the same thing but when i hit almost exactly 80mph, i hear a rattling noise from the passenger side. I dont think its wind, at least in my car it sounds like something is loose like the door panel or something.
