Front Passenger heated seat not working
cwiebe
Car: 2003 Infiniti i35
The indicator lights don't come on, the seat doesn't heat. Drivers side and rear seats work fine.
Any suggestions, or is this something that has to go to the dealer?
D_roc
Car: 2001 Maxima 20th aniv edition
did u check da fuse?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Also check the harness connector under the seat.
cwiebe
From my looking at the fuse layout, the two front seats share a fuse, but I could be wrong. I will check again.
cwiebe
I'll take a look - thanks!
cwiebe
There is only a single fuse labelled, and when it's removed the driver's side doesn't work.
Flyer88
Were you able to find a solution? My drivers seat is not working and I have already replaced the switch (it was blown) and fuse. I tested the wiring and get closed and open circuits when I expect them. The passenger side works but doesn't seem to get as warm as I remember it did.
Thanks,Flyer
gmoney718
Car: 2003 Pathfinder LE
I know this is an old post, but I just swapped out my seats (heated for heated) and same issue. My passenger side seat switch doesn't work nor the actually heated seat. Anyone experience this and have a fix?
