front of intake manifold plugs
AsanBBoy
I have one plug that has no spot to be plugged in at. Can someone post a picture of the main plugs on the front side of the motor belongs to(where tps and coolant temp sensor is at)? Or actually what does plug F25 or F24 (see fsm) go to? So the throttle position sensor is on the throttle body but where is the throttle position switch?
I dunno im getting confused. My car is a ka24de. Car is orginally an automatic car but converted to 5 speed, the motor is from an manual car. I am using manual ecu now as well. Right now the car runs like crap. Idles fine but when I gas it it bogs. When I had the orginal motor in, running 5 speed transmission, and runing auto ecu it ran fine.
Edit-So i guess the real question is, being an auto harness with a manual ecu and manual tps, this is ultimately the problem, right? So if I were to get an auto tps would i still be able to use the manual ecu? Right now as it sits I cannot use the auto Ecu, is it because of the tps or is the ecu bad (car doesn't idle with the auto ecu but it does with the manual one)?
Modified by AsanBBoy at 9:37 PM 4/4/2007
