Front Mount vs Other intercooler
lessthanjakejohn
Is a front mount intercooler the best in all conditions?
Im thinking that a front mount would get in front of the radiator and cause cooling problems in hot weather and sever conditions.
BuudWeizErr
Get a Koyo radiator and a couple of 14" high CFM fans.... problem solved :)
But honestly, you could always get an air-water intercooler.
Nils
Car: road racing
BuudWeizErr wrote:Get a Koyo radiator and a couple of 14" high CFM fans.... problem solved :)
like this =)
n
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
how much did that put you back? $500-600?
lessthanjakejohn
I have the same air compressor :)
BuudWeizErr
Nils showing me up. I bet that'll happen a lot, LOL :)
j/k Nils. I'm probably going to be rolling out to Vegas for Test & Tune pretty soon here. You know I'm going to want to see that car while I'm there.
Ace
Car: S14
Yeah I have a feeling that Nils car will show up a lot of 240's. I have 1 14 inch electric fan on the stock radiator. I can't match a Koyo with 2 14 inch fans. Oh well I just can't wait until my car is running.:D
Nils
Car: road racing
J-Spec Tuner - I paid full retail for that set-up from Heavy Throttle, Jeff has been very helpful over the phone... yeah it was about $600...
BuudWeizErr - Make sure to email me before you come out... it will probably be another 2 weeks untill the car runs... but it would be fun to hook up.
Ace - all I am really doing to the car is cooling and maintenance mods... my car wont really be super powerful, just getting all the safety stuff so the car will last at the track, but it sure is coming along nicely =)
nils
Ace
Car: S14
Oh come on Nils I know you are hiding a T51R. Don't BS me. But I am doing the exact same swap as you. 1 question whos doing your wiring? I am having Yuri do it at HT. He said it may be finished by the middle of this week. Then I plan on having it overnight delivered so its here by Friday. Then set fire to the beast.;)
Dori Dori
Car: Cars of course
To answer the original question, no a FMIC is not best in all[/all] conditions.
For drag racing, a water to air is the best. They can have over 100% efficiency when the reservoir is filled with ice (or dry ice) and water...no air to air can touch that. But for extended driving conditions (like road racing and rally), it's just added weight b/c eventually that ice will melt, the water will get warm, and the efficiency will drop significantly.
For air to air intercoolers to work their best, they need lots of cool air (duh). The easiest way to do that is to mount it on the front of the car. That eliminates the stresses of creating ducting...but proper, well though out ducting can work wonders in the means of cooling. I'm not going to go into details, but, in some instances i/c's are mounted in odd locations (under the hood of the car, flush with the floor), and of course midship and rear engined cars have them in the back as a TMIC or a ducted i/c. I reccomend reading maximum boost for a thorough explaination on intercooling.
Daunttless
Additionally, from a moderate amount of boost standpoint the side mount intercooler is the most efficient so long as it is properly aligned. Efficiency does not mean that it has the best cooling power though as it depends on your applications, it's pretty easy to overwhelm a side mount intercooler versus a front mount intercooler because of the reduced surface area, additionally if you need to move high volumes of air that low amount of pressure drop does nothing for you as the intercooler loses it's ability to cool that volume of air. Woohoo!
Nils
Car: road racing
Dori Dori is right.... its all about airflow and some custom duct work can do miracles to your engine temps. An FMIC can and will rob your radiator from good airflow, this is why I decided to get the bigger radiator and fans. I also plan on making custom ducting to lead fresh air to the radiator.
Ace - Mike Chen from freshalloy forums did my engine harness, all I had to do was to splice a wire into the steering pump. I have to modify the transmission harness a little, not a big deal though.
n
BuudWeizErr
For people who are seriously into racing, and not daily driving, you could always rip out the A/C system, and most importantly, the A/C condenser. That would feed a slightly higher volume of air to the radiator.
I H8 UR DSM
heh...Koyo heh....
heres my Trust Radiator, 1 14" fan....( i dont live out in that vegas heat;) )
:bowdown
heh, just kidding : )
lessthanjakejohn
Thanks for answering my questions guys
Cyberkreig
Car: 1993 Nissan 240SX SR
Nils -- I have the same fans as you, but one of my blades is snapped. Happen to know how to contact the company? or if the blades are replaceable?
Heavy Throttle says it was in good condition when they shipped it, just like me trans, and my ignitor, and the MAF they never sent..
Nils
Car: road racing
Cyberkreig wrote:Nils -- I have the same fans as you, but one of my blades is snapped. Happen to know how to contact the company? or if the blades are replaceable?
hmmm.. sorry about your bad luck, I have only experienced good service from HT. All I know is the fans are made by Perma-Cool, do a search on yahoo or something and see if they have a site.
Sorry, but that is the only info I can give you since I already threw away the instructions and fan info papers.
take care,n
btw - when you say snapped, you mean completely snapped off or bent?
Cyberkreig
I mean that 1/3 of the blade is missing. Causing the fan to shakeviolently when running
I H8 UR DSM
summitracing sells them....i think thats where ht gets them but i could be wrong...check their site, or catalog for more info...permacool fans..i have the same one
vboyq
Daunttless wrote:Additionally, from a moderate amount of boost standpoint the side mount intercooler is the most efficient so long as it is properly aligned. Efficiency does not mean that it has the best cooling power though as it depends on your applications, it's pretty easy to overwhelm a side mount intercooler versus a front mount intercooler because of the reduced surface area, additionally if you need to move high volumes of air that low amount of pressure drop does nothing for you as the intercooler loses it's ability to cool that volume of air. Woohoo!
Hey daunt... so what is a moderate amount of boost to where the side mount intercooler would be sufficient? How much bosst should you go to b4 setting up a FMIC??
I H8 UR DSM
most people say 10psi max on stock ic...but its debated.
mike_do
Nils did u buy the adjustable Thermostat for ur fans from HT also??
Nils
Car: road racing
mike_do wrote:Nils did u buy the adjustable Thermostat for ur fans from HT also??
I got a dual fan switch.... not really adjustable, turns on and off at certain degrees through a temp sensor/switch. But, yeah, I got it from HT.
n
Nils
Car: road racing
Cyberkreig wrote:I mean that 1/3 of the blade is missing. Causing the fan to shakeviolently when running
ouch!
The fans came that way shipped? Have you tried to get a replacement fan under warranty?
n
mike_do
this thing? ::
Nils
Car: road racing
mike_do wrote:this thing? ::
yup.. see the sensor there in the image... you stick that sensor into the radiator fins and it will read the temps. I havent installed the swirch yet but it looks like a fairly simple ordeal, even for less "electrically" gifted people like myself =)
n
mike_do
haha i hate wiring things... well not really i just hate stripping the wires.... so what all do u have planned for ur car Nils?? (mods) and what do u have so far?
Nils
Car: road racing
mike_do wrote:haha i hate wiring things... well not really i just hate stripping the wires.... so what all do u have planned for ur car Nils?? (mods) and what do u have so far?
Engine:sr20det engine, 1998 Blacktop s13sr20det ECU for 1998 Blacktop s13Custom made Wiring Harness for engine swapBlitz SS DownpipeBlitz LM fmicBlitz Nur-Spec SS exhaustBlitz Oil coolerHT SS mid pipeKoyo Aluminum RadiatorTwo Perma Cool 14" Electric fansHKS Intake AdapterGreddy GREX Oil PanGreddy Type S BoVGreddy Aluminum BoV FlangeWalbro Highpressure 255L pumpLots of "Cool It" Heat wrappingNissan 300zx fuel filterNissan sr20de oil filter
Suspension:Whiteline Front Sway BarWhiteline Rear Sway BarWhiteline BushingsWhiteline TC Rod BushingsWhiteline Rear Upper Control Arm Bushings - 2 setsWhiteline Front Lower Control Arm BushingsCusco Aluminum Front strut tower braceCusco Lower Front Control Arm BraceTein H/A CoiloversTein Front Camber platesTein Rear pillow ball tops
****pit:Cusco 6 point Chromoly RollcageSimpson 5 point harnessSparco EVO2 seat, Black one piece bucketSparco 375 Steering wheel, Black SuedeSparco Steering wheel hubSparco Steel Side MountsSparco seat bracketGreddy Boost 60mm peak hold & warningGreddy EGT 60mm peak hold & warningGreddy gauge Mounts
Electronics:Greddy Profec BHKS FCD(Soon a Mine's tuned ECU)Ignition Transistor from a 96' Q45
Tires / Rims:Volk GT-C 2 piece wheels (gold trim)17" x 9" in the front17" x 10 in the rearKumho Victoracer V700's225mm x 45mm in the front255mm x 40mm in the rear300zx 5 lug hubsH&R Wheel spacers15mm (front)5mm (rear)Nismo 60mm Wheels studs
Brakes:300zx TT front brakesFront Stock RotorsCarbotech XP pads in frontPDM Racing front SS braided brake line kitCompletely stock rear brakes
Drivetrain:Blitz Active Clutch, single plates14 VLSDOBX Short shifter
Fluids:Nissan CoolantRed Line Water WetterRed Line Synthetic Motor Oil, SAE 10W30Red Line "MTL" API GL-4 Gear Oil, SAE 70W80Red Line API GL-5+ Gear Oil, SAE 80W140Red Line Power Steering FluidMotul RBF 600 Brake Fluid
That's it for now, everything is closed to installed... when I blow my turbo I'll upgrade the fuel system, injectors and turbo. After I wreck my car I'll get a s14.5 front end.
n
mike_do
Nils wrote:Engine:sr20det engine, 1998 Blacktop s13sr20det ECU for 1998 Blacktop s13Custom made Wiring Harness for engine swapBlitz SS DownpipeBlitz LM fmicBlitz Nur-Spec SS exhaustBlitz Oil coolerHT SS mid pipeKoyo Aluminum RadiatorTwo Perma Cool 14" Electric fansHKS Intake AdapterGreddy GREX Oil PanGreddy Type S BoVGreddy Aluminum BoV FlangeWalbro Highpressure 255L pumpLots of "Cool It" Heat wrappingNissan 300zx fuel filterNissan sr20de oil filter
n
HOLY GOD!!!! :shocked2 that's alot of stuff p.s. i havent' read all of it yet =]
edit :: lol they blanked out the c0ck in c0ckpit
Ace
Car: S14
Nils just wondering if you have a hookup on Volk Racing wheels? I love them but not enough to pay retail price.:(
