electric fans are a better choicekppk1986 wrote:so is that right... should i get my old clutch fan back on or should i buy a 3300 cfm 16inch fan....
So an altima fan would work on a s13 sr20det engine with a koyo rad.? If so from which model year of altima would you use the fan from?dj_lennon_franz wrote:get rid of yer electric fan and put the clutch fan back in...i dont care what ANYONE says on this forum...electric fans DO NOT cool the engine properly...infact there was write up recently on different fans and radiators...guess what beat out all of the fans (save for the dual electric fans from an altima)...the stock clutch fan and shroud...so with that said...with yer FMIC blocking 90% of the air flow to yer radiator as it is...put yer clutch fan back in with stock fan shroud...this should deal with the problem very well...electric fans arent worth the money given they cause more problems than they solve
Gonna have to go ahead and disagree with you on this one. We've done 80 swaps, all with electric fans except maybe 4 with stock. Electric fans work fine. I run AC with one single Permacool 14" for the last 3 years with no problems.dj_lennon_franz wrote:get rid of yer electric fan and put the clutch fan back in...i dont care what ANYONE says on this forum...electric fans DO NOT cool the engine properly..
