The00Dustin »
https://forums.nicoclub.com/the00dustin-u137235.html
Thu Sep 04, 2014 3:19 am
Svard mentioning a video controller just reminded me of something you'll have to search for if you want to check it. There was a thread on this forum with a how-to for installing rear monitors in the headrests to display the video from the center console DVD player. The how-to would have hacked in between the DVD player an the front monitor, so it may not help, but it would be a good place to start, in case the video controller is located in it (there is a video splitter added in it, but that is from the DVD player output)). FYI, the rear camera and the DVD player in the center console both provide analog video while the rest of the system provides digital video. The fact that you have video problems on both analog signals definitely implies (in order of likelihood in my experience) a loose connection, a bad video switch controller, or a bad analog to digital converter. Unfortunately, I'm not sure if the digital converter is in the screen itself or elsewhere, so I'm not sure any of this information really reduces the area you need to search, although reseating the harness for the DVD player in the center console might be the easiest place to start and might affect both analog connections (albeit on separate wires, so if the behavior is completely identical on both video sources, that's probably not where the problem is). Hopefully finding that thread will help more than my rambling.
