Front main seal?
Mikey_ZX
Car: 91 Infiniti Q45 1st Gear Start
94 Nissan 300zx N/A
2008 Chevy Aveo 5
2013 Toyota Venza Limited AWD
When installing the front main seal, is it bad if it is installed too deep into the crank? Just installed one and didn't want to put anything back together if it is going to leak real bad? Please some feedback!
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
The safe thing to do is to just install another one. I prefer to have them set properly, but I doubt being in a small amount would hurt.
Mikey_ZX
94 Nissan 300zx N/A
2008 Chevy Aveo 5
Should it be flush against the outer surface of the pump? I installed to where it's basically in as far as it can go. Also, should I add vasoline to it?
marty1mc
Look at this link. Part of the way down is a pic of the crank seal. That is the way it should be installed. It also shows a good way to install them.
http://www.twinturbo.net/nissan/300zx/f ... icing.html
Mikey_ZX
94 Nissan 300zx N/A
2008 Chevy Aveo 5
Thanks never found this before!
Rich@RDZ
Car: 1991 300zx TT
It will bottom out, there are small tabs in the back of oil void, which stop it. The thing to watch out for is the inner lip of the seal turning out when installing (common problem), if this happens it with leak, remove and install new seal.
