qship96 wrote:I have noticed a couple drops of oil left on ground each morning for the last 3-4 days- took to the local gas station and had them put it on lift and remove undershield- oil is coming from around the crankshaft pully. I am assuming this is a faulty front main seal issue? Any thing else in that area that would cause the oil leaks?
What is involved in repairing the leak? How much disassembly? How much should it cost to repair? Must a specialist complete this, or is it easy enough for a local quality independant shop to handle?
I'd plan on at least a weekend. Need to remove belts/hoses radiator. Harder on 1996 than 1990 due to extra transmission cooler/hoses. Need impact wrench to remove or a least someway to keep pulley from turning. Wouldn't trust local grease monkey with anything that could cause loss of oil pressure. A specialist might be able to do it without removing the radiator.
Or you could install a bigger diaper to catch oil in belly pan.
