I'm changing my front main seal, my timing cover is not coming off. i've used everything and anything possible to try and get this off. i was wondering if there is any way to remove the Oil Pickup assembly without dropping the aluminium oil pan or is dropping the pan not an option because my crossmember isn't exactly that easy to get off the car.
thanks again guys.
