Front lower control arms
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
Noticed today while doing the upper control arms that my ball joints are totally shot.
Anybody know where to get a decently priced set of lowers? Only thing I can find is about a $300 a piece.
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
post6394996.html?hilit=lca#p6394996
The 300$ is with the entire control arm correct? So anyway, the LCAs from the Z32 to G50 are not the same. The BJs are though.The LCA bushings are as well. Buy the Spicer BJs online around $35per , the Bj seats from IoS I think $10per? + replace LCa bushings w/ the nismo ones- about... $15.per side. Aprox 120$ per side? not a very complicated ordeal!
Just have to locate!-
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
Are the ball joint seats the same as the Z32?
thanks for the info, that is the next option I was going to research.
campbelljj
Car: 1991 Q45
I have a set of control arms. The ball joints are good and they have polyurethane bushings.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
I sent you a PM with my number. Text me when you get a chance
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Are polyurethane bushings the only ones available? Does anyone have any experience with them.
IThaJ0kaI
Car: 96 G50, 90 S13 hatch
Infinitiguy19 wrote:Are polyurethane bushings the only ones available? Does anyone have any experience with them.
You can use OE style or poly style z32 bushings, for the G50.
Infinitiguy19
Where do I get OEM style bushings?
Joe at Everything Nissan is a great source.
Infinitiguy19
I thought you had to buy the whole lower control arm as the bushing is not available separately. According to the parts program they use.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
Are the Ball joint shims the same as the 300zx? I assume they are if the BJs are the same
