yeah spl is hardcore but i dont think i need that much hardcorenumbnuts240 wrote:
http://splparts.com/main4/index.htm
you won't need anything more hardcore than that.
yeah well im just looking at price options right nowbiggie wrote:That's true^.
Also can order cheaper adjustable ones. OEM ones with new balljoints and either OEM bushing or Whiteline.
Just getting new ball joints would be your cheapest option.
Since they were mentioned, ...
im not so much worried about destroying them (i have extra ones) as much as i am the ball joints going out againFN-QR wrote:If you are worried about longevity, you can just take your control arms to a welding shop and have them boxed. Its cheap, and will render them completely indestructible.
hmmm maybe i should go the way of just replacing the ball joint...im just so tired of the poppingOM3GA wrote:Poly bushings and new balljoints will be able to handle it pretty well. The poly bushings shouldnt ware for a LOONG time and the ball joints are easy enough to replace but should hold up for a good amount of time too.
Make sure you also do your tension rod bushings!
the ball joints? seems right, i was just looking at the kragen pricing for themOutToWinPAHC wrote:I got mine from my buddies work (OEM style, new for like 90 bucks for both) at his cost.
I like them very much, I haven't got to really drive the car hard yet. In the next month hope to put them to the test.poshatch wrote:how are yours working out for you?
sweet, yeah like i have them inner spacers on my tie rods, well on once side cause my friend broke his outer and needed to borrow my other onebiggie wrote:I like them very much, I haven't got to really drive the car hard yet. In the next month hope to put them to the test.
You got SPL LCAs but cheaped out on tie rods? Weird.biggie wrote:Since they were mentioned, ...
lol yea i want the spl ones as well but they are pretty pricy, i would to the route of ball joint and bushing but i want more control over camber and what not cause im maxed out right now on my top hats lolPhilipio wrote:You got SPL LCAs but cheaped out on tie rods? Weird.
I've been wondering what I need to do for LCAs lately. They're the only arms on my car that aren't aftermarket and I've heard a couple very loud clunks under hard braking. I'm thinking it's time to look into replacement.
I really want SPL but they're very pricey. On the other hand, I definitely don't trust Godspeed or anyone like that. New ball joints and bushings is an option too, I'm not sure how much of a benefit I would see from using SPL over going that route. Hmm, tough choice.
