Front Lower Brace
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
led hed
Car: 2009 Nissan Versa SL HB 6spd
hey folks, i have completed putting all the UR braces on my 09 versa, EXCEPT for the front lower brace.
i am concerned that if i remove the two front bolts and nuts to install the brace, that it MAY give me trouble to re-insert the bolt? anyone have any tips or words to ease my mind? the bolts in question are inserted from the bottom, and a nut is fastened to the top.i had the car on ramps and was thinking that MAYBE the angle of the car COULD make for problems when re-inserting the bolts, the 2 front ones.
other than that, the car corners insanely!! well worth the mod.
blindsnyper
Car: 2007 versa
i have this on my V. the only problem i had was breaking the bolts loose. getting the bolts back through is fairly easy, you just need a helper to try to roll the tire backwards and it will realign itself. i wouldnt pay to have same do it, it is easier than it seems.i did mine and ramps btw.
led hed
thanks, i think i'll drop it off and IF the price is fair. get it installed at next oil change.
for now it can wait a bit, until it bothers me leaning up against the couch there.
Return to “Versa Technical Discussions”
