Front jack points?
3rd gen Maxima. Im going to jack it up and put it on stands to change the oil. Where are the ideal spots for jack stands up front?
Thanks!
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I've never jacked mine up to change the oil. There's plent of clearance, just crawl under there. The drain plug's not far back. Neither is the filter (which is nearly as easily removed from above as below).
There really isn't a good jack point on the front of the car.Jack points are just behind the front wheels, and just in front of the rear wheels on what might be called a framerail if the car were not a monocoque.
There are little notches in the lip/seam on this rail. The car's emergency jack is designed to fit right in them. I just put a block of wood on my uber-industrial floor jack (so as not to damage the rail seam) and--uh--jack away.
If you have the manual, there's an image that shows the jack points.
danielekfuj
Car: miata, rocket ship
Where else is it safe to lift the car by? I have a 4th gen, btw.
