I already emailed you what im putting here but it might be useful to others. Note this was a 99 qx4 it may be totally different on the 01's
the grille is fairly simple to remove, I removed mine because I installed the mesh between the grille (ur lost arent you) the grille seperates into two pieces, I seated the mesh between the two pieces for a clean look with no zipties. The two pieces are bolted together via screws. I used to have a link to the complete removal of the grille but I have no idea where it is now!
Removing it is easy, theres 4 clips...2 on each side, you cant miss them their big. be careful taking them out you might break them if you arent. I used needlenose pliers and squeezed them while pulling the grille towards you, one at a time. Then in the center of the grille directly behind the infiniti logo theres a screw that needs to be loosened, the screw uses flathead screwdriver. This is the hardest part of the removal. I posted pics here...
zer...erial
