amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Mon Aug 20, 2018 4:31 pm
Went looking for a minute, you have to understand I've never seen one of these before..........
You'll need power brake source, fuel pressure reference if that type of sensor, HVAC supply if using it, boost gauge source, two lines for carbon canister (control and flow), wastegate vacuum, and breather for the other half of the PCV system to vent the crankcase. Maybe 1 or 2 more based on things I haven't found yet. Delete any things there not used. You gotta plumb all that up so it makes sense using the vacuum takeoffs you have, any others get plugged.
