Front End Wheel Chatter
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
Wartboy
Car: 2011 G37x S Coupe
I have a 2011 Infiniti G37x S Coupe which I just changed the tie rods, balanced and aligned it. Thinking the chatter when I go over bumps is most likely the front shocks even though when you push on the front end they seem okay. Any suggestions or confirmed causes?
Reason: Moved to correct Forum
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The most likely culprits for chattering noises over bumps which don't seem to affect the steering is usually the sway bar bushings or links. Have you checked those?
Wartboy
Thanks! We'll look at that.
Dbarry
Car: Nissan 240SX
There's an Infiniti G37XS Coupe my buddy is interested in. The owner mentioned this intermittent squeak or chattering noise. 78k miles but neat overall. We'll just finish installing the bumper, nerf bars, and fenders on the truck tomorrow before we take a closer look.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
