robthebert »
https://forums.nicoclub.com/robthebert-u70654.html
Sat Aug 18, 2007 6:02 am
Hey guys,I have a 95 gxe and im trying to pinpoint this front end vibration issue. What ive doen so far is had the cv axle replaced, front end alignment; both by pep boys. I also have had all tires reballanced and rotated, I even rotated the tires a few times to see if anything changed and nothing did. Before the alignment the car pulled to the right, more so at higher speeds. Also the driver side shakes or vibrates. It really dosnt start to vibrate until i hit just over 65 mph and more so above that. Even after the alignment it still pulls to the right. The driver cv axle was bad so thats why I replaced it. I lnow its not the bearings cause I jacked it up and already tried to move the wheel around and there was no play. I need to get it fixed, I travel to California and Arizona back and forth on the weekends. Any ideas would be great. Thanks in advance
