Front end turn signal issue
HlMSA
Car: 1991 300zx N/A
need help from the pros... anyways my front end turn signals wont flash anymore, they turn on but they wont signal pretty much. I checked the fuse already, i think i checked the right one lol, anyways if it was the right fuse, it isnt burned out. Only other thing ive read online is that it might be the relay, would that mean the flasher relay? and if that was the case, wouldnt the back end turn signals not flash aswell? uhh anyways im hoping someone on here could help me out... :frown:
HlMSA
Car: 1991 300zx N/A
well i fixed the left turn signal, but the right turn signal wont turn. As a matter of fact when i signal right, the green arrow flashes too rapidly and the right rear signal flashes quickly aswell..
emt-z
Car: 1993 red 300zx n/a five speed
dont mean to sound like a smarta$$ but are you sure the hi side element of your bulb is good or that your connection is good at the bulb base? the fast flash usually means too much is coming through the circuit. i had this problem with mine not too long ago, i just left it out of the lens, turned on the signal an it worked when i wiggle it around some. i replaced the bulb an have not had any problems with it since, it just didnt like that bulb. hope that dont sound like a smart answer but sometiumes it is something too simple, hope it helps a little
HlMSA
Car: 1991 300zx N/A
uhh well the bulb is new, ill try trouble shooting how you mentioned, ill see what happens.
