Front end shakes under heavy braking
Checkered Flag
Car: G37X 2009
So I have had issues with my front brakes shaking under heavy braking. I presume its that.... the rooters must be thinned and the brake pads themselves are wearing down.
This has happened before, and was corrected last time I had a full front end brake job. What exactly causes this? Will turning the rotors help, or hurt the situation.
PS Only happens when strong braking from like 90-100 back to 65 (ie when passing!)
Checkered Flag
Car: G37X 2009
I presume new pads won't help? Or turned rotors? Just new rotors and pads??
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
Rotors... switch to some drilled rotors or both drilled/sloted. The stock rotors can't handle any real aggressive driving. The stock pads are actually pretty good.
joe603
Car: 2014 Durango R/T
Agree with Kmckis....aftermarket rotors will help. The shaking is probably because the OEM rotors are warped.
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
I didn't think that the oem bads were all ceramic.....causing too much heat for the OEM setup.
My g35X has warped rotors, but the pads are fine. Shakes under hard braking.
Doesn't bother me or my wife, so going to wait a bit longer before putting on new rotors and ceramic pads (Akebono pro-act). Told all ceramic will generate less heat.
But, we don't track ours......so, yeah, if you are aggressive then follow their advice above.
audtatious
Some people have a bad time with the factory rotors constantly warping. It's all about how you drive. Personally I'd suggest replacing them with StopTech slotted or Brembo blanks.
Checkered Flag
Car: G37X 2009
Thanks I was having log in issues or would have responded sooner.
Any preference on make of new rotors????
Mudgen
Car: 2011 Graphite Shadow G37x sedan (Jezebel), 2011 Dark Gray Metallic Subaru WRX sedan (Darth), 2006 F150 XLT 4x4 5.4L 4OT (Big Brown)
I used to have problems with warped rotors all the time until I learned not to drive through puddles after runs with hard braking. Hot rotors and cold water guarantees warp.
Avoiding it does not guarantee no warp, but I have not had the issue in years.
audtatious
Checkered Flag wrote:Thanks I was having log in issues or would have responded sooner.
I'm running StopTech PowerSlots on both of my cars and are very happy with them. if interested in pricing I suggest shooting Mike (RED_DET on this forum) a email for pricing at http://www.tunerzstore.com
Checkered Flag
Car: G37X 2009
Thank you. will do. I presume we are just talking front end, right?
audtatious
I usually change them all. Right now I have only changed the fronts on the sedan and the rear is warped again. If I keep the car much longer I'll replace the rear with StopTech.
