I have a problem that has been posted a few times with no final update as to the solution. I also have a few small differences.
I have a 95 240SX 109K miles. It is the fist S14 sold in Arizona. My dad worked with Calsonic at the time, they had dibs on the first shipment.
It starts shaking, Front end, mostly steering wheel, at about 65 gets worse all they way to 100. at which point I can't hold the wheel anymore. Steering is tight but occasionally pulls hard to one direction or the other for a short ways then stops. This is regardless of road crown, sometimes it will pull up crown, sometimes down. It will also track the road groves with a death grip. Maybe some how related, the right front tire is very easy to lock up, both before the upgraded brakes and after.
What I've done since it started: New tires, then new tires and wheels (upgrades 18 x 8) balanced several times at discount (morons) then at a specialty shop who does VERY high end, Ferrari's, Lambo, racing, etc. They used a road force for roundness, construction, fit to whee and balanced to 6 grams, Discounts balance was off over an ounce and on multiple wheels. Added concentric ring. The tires are Falken Azentis RT 615 or ice skates as I refer to them as because the temporary spare grips better.
New AGX struts, swift spings (camber corrected), Koni Mounts, Tein tie rods and ends, polyurethane rack mounts, polyurethane tention rod bushing, larger sway bars, Q45 brake upgrade, aluminum driveshaft and Nismo motor mounts and transmission mount. The last two were to fix age related problems. I even changed the valve stem caps.
My fiancee is tired of the money pit but I need to fix it. She just got a new A4, but this will have to last me until end of this year. I'm thinking either the new tension rod bushings or strut mount was replaced wrong or I have a bad wheel bearing (which is rare for this problems as I've heard).
I haven't been able to drive on the freeway for 2 years with this, old Datsun 720 time. Please, somebody who's delt with this help me.
Thankyou MUCH in advance.
