Front end popping
phillip fair
Car: 1993 240 sx convertible
I first noticed the problem about 6 months ago when I had to come down hard on the brakes. I noticed a light thump when I appied the brakes so I put it up on jacks and pulled the wheels off and and checked all of the front end components I ended up removing the calipers and pins inspected and regreased the pins and systematicly lubed every place I could think of it was all quiet untill about 2 weeks ago when it came back. The only thing I can think of now is that my aftermarket adjustable tension rods might be the culprit. Have any of you experinced this problem and solved it?
ZiG
Car: 1993 240sx coupe
check your upper strut mounts.
s13_chris
Car: 90 240sx Hatch
Just to throw it in, but when you mentioned brakes I thought of the rotor. Check for like.. chirping? of the brake pads. If there is a line, then a inch or several centimeters later another solid line on the rotor then you may get them resurfaced. Just a thought
da240
Car: 98 Coupe
I had a similar problem, it turned out my tension rod bushings were shot, replaced them, and no thump. Did you lube the tension rods when you jacked the car up, and if you did, try lubing just the rod bushing and see if it goes away, if it does then replace the bushings.
phillip fair
Thats what I was thinking my tension rods are adjustable after market ones and it has a ball and socket in the end that connects to the frame I'm thinking of smearing the ends with grease to see if that helps. Thanks for your input
BoBa524
Car: 1995 Nissan 240SX SE
i have the same problem but i have 300zx brakes... i've always thought it was brake pad slap(movement of pads usually cuz they are aftermarket and not OE.)
I've had bad tension rod bushings and that shiznat is harsh feels like the whole front end shifts.
si1via
Car: '93 240sx
yeah check the tension rods connections.
slow40
Car: S13
My front end popped pretty bad when I got on the brakes after doing my 5 lug conversion. check the tension rod bolts that go thru the lca. Mine were not tight enough, allowing them to slip and "pop" the arm. Good luck.
And sorry about this, but boba, that chic is killing me man, where did you get that pic.
Ligerzero
Car: 92 240sx
Most likely your bushings....not the struts. Struts will pop when you are turning if the bearing and upper perch is bad...
BoBa524
lol her name is keyra augustina jst google it.
qksilver1
Car: 1996 240SXSE 5sp Pearl White w/leather interior
How did you make out - did you find the problem? My car is starting to do that a little.
slow40
Car: S13
wow dude, never realized that poo can come out of something so nice. If I was a teacher, I could give geometry lessons with her
91nissantwo40sx
phillip fair wrote:Thats what I was thinking my tension rods are adjustable after market ones and it has a ball and socket in the end that connects to the frame I'm thinking of smearing the ends with grease to see if that helps. Thanks for your input
hey i am having the same problems also. i have replaced my front lower control arms and got new adjustable tension rods but the noise seems to still be there. i was wondering if greasing up the tension rods worked for you?
