Mark Mellott »
https://forums.nicoclub.com/mark-mellott-u229493.html
Sun Dec 29, 2013 6:38 pm
That was a familiar description of a strut that is gone bad. Check to see if there is any hydraulic fluid that has leak out of the strut rod seal. Even if there is none, the internal strut workings may still be worn out. The strut rod moves in and out of the strut body with a constant resistance. When the hydraulics wear out there is often thud-like sound when the rod sees no resistance for a moment and moves unrestricted in or out for a short length of its stroke. When it then sees resistance, a thud-like sound is heard. At 91K miles, the struts are probably due for replacement.
