front end hops really bad when i spin the tires
2000maximagxe
Car: 2000 nissan maxima gxe
when i launch from a dead stop or dumb the clutch from a roll, when the tires spin, the fromt end hops really bad. like i thought the dash was going to fall off today. i dont know what it is. i know in a rwd you can get traction bars but its rwd.... what can i do to stop this...im not trying to shake a can of paint when i launch.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
The Maxima actually has a sway bar (traction bar, stabilizer bar, anti-roll bar, whatever you want to call it) in the front.
Wheel hop is really just an unfortunate side effect of FWD's dynamics. It's more of an issue than RWD, even without sway bars, because FWD shifts weight off the drive wheels during acceleration, where RWD shifts weight ONTO the drive wheels.
The BEST way to prevent wheel hop is with a limited slip differential. It'll keep just one wheel from spinning, which is what causes wheel hop for the most part. With an LSD you may still get a little wheel hop, but it'll be brought under control quickly.
You could also install a stiffer sway bar.
However, stiff front sway bars aren't really ideal as far as overall handling. In general, the stiffer your front sway bar is, the greater the car's tendency to understeer will be. And since FWD cars are already very prone to understeer, that's not really ideal when it comes to handling overall. A stiffer rear sway bar and softer front sway bar is the ideal setup for reducing understeer. But of course totally eliminating the front sway bar leads to other negative side effects...so you have to find a balance.
Of course, there is also another, simpler option: Better tires.Better (superior traction) tires won't slip as easily, and thus won't be as prone to wheel hop.
Lots of wheel hop might also be a sign that you need new shocks, as good shocks should also go a long way toward dampening wheel hop.
saylee
Car: 1998 Maxima,1993 mr2 turbo
i had the same problem but when i switched shocks everything was fine but i have adjustables so you can stiffen the suspension when you want..I also recommend the stillen sway bars, probably one of the best upgrades i've ever done...GOOD LUCK BRO TELL ME HOW IT WORKS OUT FOR YOU!!
lightsout
Car: 00 Nismo Maxima SE
1. tires outa balance?2. brembo blanks eliminate the stock rotor warp.3. upgrade strut to adjustable strut or coilover.4. sway bar bushings.
