Yes, you are looking to see if there is a lot of free play in the sway bar links. If they link bushings are worn then you can pick up a pair of links for fairly cheap. If you push down on either front corner of your vehicle and it makes the cluck noise then you will most likely have to replace them.qx4dude wrote:What am i looking for when looking at the linkage? Warn bushings?
