usc45 »
https://forums.nicoclub.com/usc45-u16426.html
Sun Jul 25, 2004 10:30 am
i'm hearing this clunking noise from the driver's side front end everytime i make a left turn only when the suspension is under load. it's kinda hard to explain, but it sounds like a bad balljoint or something along those lines. i've been under the truck shaking various suspension parts from the end links to the whole control arm. i've also jacked up the truck to get the load off the suspension while doing this. i checked for bad balljoints as well as bad tie rod ends, but all is tight. the noise also happens if i hit a fairly large dip or pothole in the road while going straight. this has been happening since i bought the truck 2 months ago even with the oem wheels. at first i thought it was the hood, so i didn't really make a fuss about it, but adjusting the rubber hood stops didn't do a thing. any ideas what this could be? or should i bring it into the dealer and have them take a look? if i'm not explaining this clearly, please let me know as well. thanks.
