Front end clicking sound.
Whitehatchwonders13
Car: 1993 240sx hatchback
powered by Max Coilovers
Welded diff (yee!)
Alright so for the past month my car has developed a clicking sound that starts off as a light scrape at low speeds then gradually becomes a click as the car accelerates. I have a 1993 240sx with 5 lug conversion and 300zx brakes up front. I know the sound is coming from the drivers side front wheel but I can't pinpoint exactly what's causing it. It also cannot be replicated with the car jacked up. I've already tried a new hub assembly and sadly that didn't fix it. Any other things to consider??
blkvrtswp
Car: 93 240SX Convertible
SR20DET FP 20G Turbo
Check your brake dust shield - it could be slightly bent and hitting your wheel or something. Or it could be a wheel bearing.
Good luck!
