How are your T/C rods? Check the bushings, if goo is coming out, that's why you are getting a vibration. Keep in mind, tires/wheels need to be balanced ever 3,000 miles or so (or every oil change rather)BGdude wrote:Would a bent wheel cause the shake? Perhaps the bushings? Wheel balance is a must. I'm having the same problem around the 50mph area and although I have balance and alignment done, I still experience the shake. I think its due to the bushings being worn out and one of my rear wheel is bent.
