Issac »
https://forums.nicoclub.com/issac-u89863.html
Mon Mar 17, 2008 5:15 pm
Yah I got some experience in this. Same kinda story. no answer to my question on driveshaft, so I found out myself.
The front driveshaft does come off and does not leak oil on my 2002. It has flanges on both sides and no sliding.
Your driveshaft may be fine and it could be u-joints. It might be out of balance also? $60 to get balanced around here for each shaft. I might have to do that also.
*Most important thing!!!! Mark your shaft postions all the way thru, real clearly, like punch marks, filing lines, etc. The factory does this with white and blue paint but it can wear off. Do this before taking anything off!
The bolts are kind fun to take off. I couldn't get my socket to fit, so I used end wreches. 2 x 14mm wrenches. You need strong ones. I broke TWO of these taking the bolts off. Gym work maybe...
Anyway, you have 4 bolts front and rear of shaft. My driveshaft came off and I don't have AWD, so I could drive it without.
You will torque the heck out of the front driveshaft if you don't counter the force of loosening the nut. So I put one wrench on a bolt in the front, and one wrench on a bolt in the rear. The whole shaft is short. 2 universal joint.I ended up using a hammer later to give shock to the bolt and that worked too.
You can do 3 bolts on each side, then have to move the car forward 2 feet to get the other.
Then you got to compress the shaft, buy pulling it to the transfer case, and down in the front, to get it off the flange. If this doesn't work, take off the grease fitting to let grease out.
Tighten the heck out of the bolts when you mount again, then drive for a bit, and go at them again. I think it is like 85 lbs torque. Check this.
I had vibration issues, tried much, and narrowed it down to Front Differentail carrier bushings, which I did myself or you can buy Nissan part with arm and bushings installed at $80 each and there is an onilne nissan parts place out of FL that ships these. It is a Nissan dealer I believe.
Little hard to get to bolts, but not hard from there. Just put support under differential to keep it same height. Do one at a time, you have to lower the diff slightly to get the arms out. No major but takes a little time.
If you look at yours, the differential is supported by these 12 inch hangers. They have bushings on each end. The differential hangs real loose on these and I strongly suspect the vibration is the center of these bushing not being anything close to center under load. Mine were way to one side. Which means less shock absorbsion and...vibration.
I would get universal bushings from suspension.com because the guy is cool and not an *** like many. You need to get measurements, which I plan to give him, to work out the exact bushing. I will be doing this when my patch method wears off. It has helped much, but not totally.
But my u-joint in the front driveshaft was tight on one axis also. I have 92K on these. So I took them out and pressed in new ones with grease fittings. They only cost $15 to 20 for these. This is a little harder than some u-joints though. Harbor Freight makes a knock off of a $350 tool that is identical for minimal use. It cost around $40.
When you pull your driveshaft, check u-joints. Mine had a tiny slack and also tight on one, one plane. Ok I am done
