Wow I totally mis-read/didnt comprehend... the name of this thread. Guess I was caught up in my own bs issue and thought I had found someone to commiserate with.
In the FAQ thread in my signature, I made a 'howto':Malbec 56 Beast wrote: ↑Fri Aug 17, 2018 2:06 amAre there a tutorial on how to do this. I would like to do some maintainence on them but haven't a clue what to do.
Are there pics that show this procedure.
Thanks
Andy
Those images weren't mine (for the seat) as I forgot to take a picture. Mine were quite dirty though. I don't remember how much change there was but I plan to do this soon again so we'll see.Malbec 56 Beast wrote: ↑Fri Aug 17, 2018 9:57 amThat is great, I just went through it, did cleaning the filter make that big of a difference. It doesn't look like it was enough to cut off airflow.
Was that worth it?
Thanks for doing that.
Andy
Nope, developed a more intense issue with a front end rattle that has been driving me up the wall since last March or more......and still have not figured it out...
VStar650CL wrote: ↑Mon Jan 03, 2022 5:05 pmThe problem in this bulletin is particularly prevalent in Muranos, but it can happen to pretty much any climate seat employing a Peltier element. Peltiers draw a lot of current even in a healthy system, and the unhealthier the airflow, the more they draw. All it takes is a clotted filter and some time for a Peltier to turn into a Meltier.
https://static.nhtsa.gov/odi/tsbs/2019/ ... 9-9999.pdf
Your mechanic is misunderstanding the root of the problem. The climate seat controller has circuitry to detect a stalled or slow fan and will actually kill the system if the fan no-starts. The actual culprit is reduced airflow through the TED (Peltier element). It's a well-known characteristic of all Peltiers that the hotter the "hot side" of the element gets, the more current they draw. The heat is supposed to be sinked and sucked away by the fan, either as waste heat when cooling or to warm the seat when heating. When ventilation is removed or limited, current into the Peltier runs away and eventually overheats the ground connection to the controller.
Replacing the switch was completely ignorant. The switches simply signal the climate controller and carry almost no current. Blue moons are much more frequent than failure of those switches.
It doesn't melt from a short, it melts from resistance in the connector pins. Completely different animal.
The problem is that the harness connector melts, the controllers are very easy to change by simply unbolting the seat. The harness is another matter, replacing that requires seat disassembly. Nissan issued a repair pigtail along with the bulletin for the Muranos and Titans, but for some reason they haven't done so for other models. However, that connector kit can be adapted to repair most other models. You just need to go by the connector pinout on your car and ignore the wire colors. The part number for the pigtail kit is 24061-9FT0A. Do NOT try to reuse the climate seat controller, always replace that even if you're able to remove the melted connector. Very often the circuit board and/or driver FETs are damaged internally, so reusing the controller can be hazardous.
Andy, I can tell you 90% of how to do it because I just did it. You need 2 socket wrenches, one that fits the battery connection and another one that is a 14MM. Get in the car and move the seat as forward as you can, turn it off, and now use the 14mm to unscrew the rear bolts AFTER you take the darn plastic covers off with a flat-head screwdriver and some scraped-up old skin. Once that is off, reconnect the battery, and move the darn seat back, disconnect the battery, and now unscrew the 2 14 mm front bolts AGAIN after removing what the engineers thought would be nice to cover the rails. Once that is DONE, you can tilt up the front seat and PHOTO EVERY DARN THING in there. Because once it is down you will NOT remember any of it.. Once done reverse the project......maybe 45 min max without any liquor....maybe....maybe not, anyway it works. And you get to clean under that seat which has not been done for YEARS!Malbec 56 Beast wrote: ↑Fri Aug 17, 2018 2:06 amAre there a tutorial on how to do this. I would like to do some maintainence on them but haven't a clue what to do.
Thanks
Andy
Ok, the pins have power and none of the connectors have been melted. I "THINK" that maybe by having the wooden carpet-covered PLATFORM in the back seat that when I slide the driver's seat BACK it might have damaged a sensor in the rear of the seat? I am going to try and find a seating diagram to see if there is one back there.VStar650CL wrote: ↑Tue May 23, 2023 1:55 pmHas to be either a power or connection issue, or the seatback Peltier is shot and overloading the controller. The controller only needs a few milliamps for the switches but needs amps for the fan and Peltiers, so the first thing is make sure the main power wires will light a bulb-type test lamp, and make sure the female pins in the black connector aren't trashed. They can heat up and blacken or deform without actually melting the plastic connector body.
