Front driver's door won't close / Puerta conductor delantero no se cierra
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
PiciasBrivi
Car: 2016 Infiniti Q50
I know that the forum is in English, and I apologize since my English is TERRIBLE.
The problem I have is that the driver's door stays open, the alarm comes on, but when I press the button on the
command to close, the actuator does not lock the door. Why can it be?
Thank you
Se que el foro es en inglés, y pido disculpas ya que mi ingles es PÉSIMO.
El problema que tengo es que la puerta del conductor se me queda abierta, la alarma se enciende, pero al dar el botón del
mando para que se cierre, el actuador no bloquea la puerta. Por que puede deberse?
Gracias :tisk: :mad:
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Do you hear the actuator operating? If not, chances are you simply have a bad actuator.
PiciasBrivi
VStar650CL wrote:
Wed Dec 07, 2022 6:35 am
I start to drive and I hear the doors lock
VStar650CL
Technical Expert
Yes, but there are four actuators, one in each door. You need to put your ear to the driver door and use the lock/unlock button to work the mechanism. If you can hear it operating then you may have a broken cable or bad lock, if you can't hear it then it's probably a dead actuator.
PiciasBrivi
VStar650CL wrote:
Wed Dec 07, 2022 9:08 am
some fuse?????
VStar650CL
Technical Expert
No fuse, the actuators are all powered from the BCM. If one has power then they should all have power.
Return to “Infiniti Q50 / Q60 Forum”
