Driver-side trim seal panel part #: 80839-1MA1A
No I don't believe so. I squeezed the tabs on one of the clips from the new panel to show it here. I can try to rotate then to see what happens.
I was hoping I didn't have to just cut them. I don't want to have something possibly rattling in the doorVStar650CL wrote: ↑Sat Dec 20, 2025 8:35 pmNissan doesn't use very many of those, they're pretty much just for thick rubber or plastic. When they're used in a keyhole they can be rotated and removed as @Ilya suggested. However, if they're in round holes then you won't get them out from the front side without distorting the sheet metal, they can only be cut or drilled. The fact that they're usually destroyed when removed is the reason new panels like those always come with new clips. Cutting the heads off and pushing the shafts through is simplest. Because they're plastic, the cut ends won't generally cause any audible noise when they fall inside a panel.
