Rogue Jarhead »
https://forums.nicoclub.com/rogue-jarhead-u216599.html
Wed Aug 23, 2017 7:18 pm
You tube has several videos on fender replacement, although not on the rogue specifically most all vehicles are similar. There are a couple of rogue videos about inner fender and headlight replacement, those may be worth watching as you'll have to remove those items also. The hardest part is usually getting the fender lined back up properly and all the gaps correct.
