Front Door Panel Removal
timatt
Can someone tell me the tricks necessary to remove the front door panels on a '91Q. I want to replace my speakers.
thanks,
timatt
DougQ45
Car: Q45, porsche 928 S 5 speed
See http://www.carstereorepair.com. They have a step by step illustration.
timatt
This link is to a page that is under construction, and nowhere on the page can I find a like to any sort of removal illustration.
So I pose my question again. How do you get the interior door panel off without damaging anything?? All snaps, clips and fasteners are not obvious to me, so I would like to know where they are before I start prying on anything which might cause damage.
Thanx
timatt
DougQ45
Sorry. Make that http://www.carstereohelp.com. Go to the Infiniti section and follow the illustraded directions for speaker removal. It was very easy, and much better than if I try to explain them to you.
DrewQ45
Car: 1990 Infiniti Q45
Start by removing the armrest on the door. (the part that your forearm rests on) You do this by pushing it forward or backward??? (memory fails but you'll figure it out).... Once you've got that off the rest is logical.
...Drew...
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Slide it towards the back of the car, with the door open (this is true, for all the armrests). The switch control panel is tricky to get off, without breaking it. I have broken 2 of the 3 I have taken off, so far. Luckily, the breaks are slight, and the parts are re-usable.
