Front door grommet and wires
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
Can anyone confirm if the grommet and hose from the body to the front door has a connector on the body or if it's just a hose that wires run in from the body to the door?
svard75
Car: 06 M35x
All knowing all data states "Pull the lever and disconnect the door harness connector while removing tabs of door harness connector."
Whatever that means. I think they're suggesting the connector is only removable at the door and when removing the door this connector stays attached to the body.
